Budget coilovers - worth the gamble?
Update on these.
They have now done XXXXX miles - including 2 fully laden camping trips to France (rural potholed roads and ridiculously severe speed bumps)
All was well until last week we were approaching Saint-Nazaire. Driving down a half-resurfaced road, there was a reasonably load bang and the parcel shelf jumped up into the air. I pulled over to investigate, and found the damper rod had come up through the top mount and was pushing up onto the speaker supports.
With around 1000 miles still to drive, this was a bit of a problem.
It was hammering down with rain and I had no tools (other than a jack and wheelbrace) in the car at all. After limping around for 10 minutes we stumbled on a massive Hyper U supermarket which had an underground carpark - what a godsend.
After unloading the car I sent Kate into the Hyper U to try and find some tools - I reckoned a cheap spanner set or a couple of adjustables would be enough. She came back with 2 adjustable spanners.
I locked the damper rod with one and used the other (awkward!) to free off the top mount retaining nut. This allowed me to remove the topmount rubber which allowed me to see the damper rod and the problem became clear.
Look at the rear coilover on the left of this picture:
The damper rod is held to the top of the car by the top mount. Then you have the silver uppe spring cup which holds the spring in place. To stop the damper rod simply rising until it is fully extended, it needs a protruding lip to prevent it's ascent through the spring cup.
This is done with a simple washer, and this was the problem. The washer had sheared, so there was no longer anything stopping the damper rising up through the car.
So I had a think and looked at what I had to hand - the top mount itself does very little work and contains a number of parts which I reckoned it could manage without. The upper topmount rubber is stabilised by 2 pressed metal washers. You can see one of them underneath the retaining nut in this picture:
I reckoned if I could "borrow" the lower one of these washers, I could get it to do the job of the sheared washer.
Unfortunately, to do this I would need the damper rod pressed all the way down so that I could lift the spring cup and slide it in. With the damper on the car (no tools to remove the bottom bolt) this would be tricky.
With the car supported on it's own wheel I realised I needed to get the rear beam as low as possible to stand any chance of doing this. Standing on the hub or levering it with a bar wouldn't cut it.
So, I put the scissors jack between the body and the beam and gently began to jack the 2 apart. It worked perfectly and down came the coilover as a whole. I could now pop off the spring cup and slide on the borrowed washer. With Kate pushing down on the damper rod with the handle of a hammer this was achieved, the spring cup went back on, unwind the jack, refit the top mount (minus it's lower pressed washer)
Job done! Took about 40 mins I suppose and left me with very dirty hands.
Moral of the story? Cheap coilovers work fine but are made to a budget. Don't be surprised if relatively minor parts like this fail with hard use. The top mount (minus it's stolen part) has been fine since the repair and doesn't seem to miss the washer. I'll still replace it though.
I'm now going to replace the other damper retaining washers with these ones from the rear topmount kit - they fit perfectly, seem stronger, and are IMO an improvement on the original design.
You can tell he loves it. Just look at the smile on his little face ;)
I forgot to tell you that I had some disposable gloves packed for hand protection on such an occasion. Oh well :D
Missed this thread, I've been tempted by these myself. My current setup of Venom Motorsport -60mm springs on standard shocks (combined with the whiteline rear ARB) handles nicely, but it does seem a little soft and under-damped, and not as 'sharp' as I'd like.
I might take a gamble and go for it, I don't mind a hard ride, in fact I actually like it. Oh, and I'll fit stronger washers before fitting them ;)
From my experience with suspension, you will need to change them again within 2 years.
Cheap is often cheap
Jack with no axle stands = muppet
So the moral of the story here is that they were cheap and people were not sure of the quality of them. You fitted them correctly and carefully, and then they broke shortly afterwards. Thus leaving the average joe who would have paid a garage to fit them in the first place, stranded in france, needing a potential recovery all the way back to england, followed by another garage bill to correct the damage.
Great :p Worth the gamble for you as you know what you are doing, but after your story i would pretty much take that as a no go product!
I bought a similar brand of budget coilover (Since theyre the mid market lot unbranded and dismissed due to not being the same level (does this matter with coils - no))
Had mine in for about 15months and theyve been great.
Not the best handling suspension in the world but they tie in brilliantly with a nice whiteline RARB :)
The selling point is the 2 year warranty thats put on the product, they could break after 2 years and id happily buy another set given the price..!
One thing though, make sure you get them properly set up after fitting, cost me £30 for 4 hours worth of suspension fiddling and was a whole different drive :)
:confused:
In the OP he is only using the scissor jack to raise the rear arm up to meet the bottom of the shock to put the bolt through, there will be too much resistance to hold it up by hand easily while trying to push a bolt through and thread it correctly.
LOLZ, with some extra LOLZ just for effect.
My cheap coilovers have been fine for over 2 years and 30k of abuse.
And Lopez isn't using that single Jack to support the car.
:confused:
Sorry, was not a dig at OP
Just a little warning to the "Muppets" that work on there cars without axle stands
On the pic on the sig? If so then thats a good sign for the rest of us if theyre coping well carrying a heavy VAG Estate!
+1 for axle stands, you MUST have the car properly supported when working on suspension or its not going to be pretty if/when it fails and your car drops to the ground...!
I wouldnt want to be picking it off the ground if something gave way!
The coilovers on the passat wont be the same as the ones on the golf..... so it doesnt mean much really!
I have worked on the car without using axle stands for changing brake pads and discs, bleeding brakes and its been fine, your not under the car at any time. For lying under the car for any period I would use an axle stand.
Yeps got them fitted to the bus.
Build quality is fine imho, i can still turn the platforms on the threads and nothings jammed up, no leaking gas / oil, ride height has stayed constant since the initial bedding in period, ride quality has stayed exactly the same and is no harsher than my mates 06 Leon with 17" wheels.
For the money i'm very impressed, its given me exactly what i wanted at a great price, granted if you spent £800 you would get a much better setup, but at the end of the day an £800 coilover kit isn't going to turn my Passat into some back lane stormer and i doubt it would make the car drive any better.
I stuck Daiyama coilovers on the Civic back when no one had heard of them. They were dearer than the option in here at £400 (Entry price for guinea pigging them but still choice of spring rates) but the next cheapest coilover option was £200-£300 more expensive. They were great for the 2-3 years or so I had them and never missed a beat.
The paint had started to come off a couple of the coils when I sold them but they came up a treat.
