- 14 Sep 2007
What's DD-WRT mate?
Its a firmware for routers i believe is compatible with the virgin one that you are given
What's DD-WRT mate?
Power level is a little high, but not enough to cause you too many problems.
May want to consider a 3dB attenuator to see if that helps - I might have one spare to send you, I'll let you know later.
SNR is fine too, but you are getting a fair few uncorrectables - I'll compare it to mine later, but I'm sure I've got a low low number of them.
Shouldnt the downstream ds-4 have a value ?
Sorry to highjack, but it doesn't really warrant its own thread...
Do you Virgin 50Mb guys still get uncapped downloads and if so, is there any indication that this will stop?
Secondly, did you have to pay £55 up front for installation and connection? They won't let me do a self-install for some reason.
Thanks for that. Sounds good but still debating whether it's worth it for me, who is a casual user at the end of the day.
