we don't want to spread too thinly - that just results in not doing particularly well at anything.
Most of the big projects have OcUK teams, but we don't want to spread too thinly - that just results in not doing particularly well at anything.
I'm all for crunching on a second project, can anyone tell me which of the projects above support fermi? If i was to crunch on a second project and both used fermi gpu how would i set a preference for a particular project to use the gpu over the other as i take it both could not be using the gpu at the same time....Thanks
Thanks for that H much appreciated as allways, one teeny last thing when you highlight the seti project in boinc you get the additional buttons down the side pref/results/computers/team when i highlight milkyway at home all i get is the milkyway web site, i can go to my mway account page and see team from there just makes it easy to keep tabs when its right there in boinc straight to team.
Will mess with settings so i can let mway have cpu time....TBag is on the case
Question (dont look suprised) i want to use the cpu only on a rig with a fermi card in (which will remain devoted to seti) is it a matter of messing with preferences on milkyway account page, and if i do it's going to stop me using gpu on second machine yes so need to make a home/work pref?
Sorry for all the questions chaps just want to make sure i get it right and am happy to support Mr Halz Sah in his new found role
Thanks for the pointer Edge i will stick to home/work profiles at the minute, dont think i could handle another optimised apps fiasco just yet!
Halz thanks for that pointer but i couldnt handle that on top of everything else - your talking to someone who left his spoon in a coffee then decided to warm it via microwave.
"Small steps sparks...small steps"
Fermi does work with milkyway, I have seen posts with people running the new v3 app, but where you get the app from is another matter.
So we need someone who can sort this then .........
http://milkyway.cs.rpi.edu/milkyway/forum_thread.php?id=1681&nowrap=true#40554
