Caporegime
- 29 Aug 2007
- Auckland
Just use disposables myself, single blade infact there made by BIC yes the people who make biro's, I can't tell the difference between it and a top of the range gillette or wilkinson sword and there cheaper.
A DE razor will give the vast majority of people a far, far better shave most of the time. If you're happy with what you currently use then there's no issue
As has been said before in this thread, a DE razor plus cream or soap and brush will give a better shave and will be cheaper than other options. It does, however, demand that you have longer to spend on shaving than a BIC or Mach 3 approach.
, currently using a large t cup until i can find something better.
. However the problem is I don't want to grow it any further but how do I keep this beard without resorting to shaving again and waiting 3/4 days for it to grow back again?
