Want to lose 10stone.
Permabanned
26 Jun 2010
I want to lose 10 stone, I have been told by a nutritionist that a low GI diet would be a good start, which is great but She didn't really give me any menu options or foods to eat or avoid.
I have a very sedentiary lifestyle although I have just pruchased an Exercise bike and a Weider compact90 multigym and would like some tips on using the Gym especially.
Thanks in advance...
Search for "the testosterone advantage plan" published by mens health. It is out of print but you can get plenty of copies through amazon retailers.
High protein low GI. Also has some great muscle work outs and is a nine week plan.
You wont loose 10 stone in 9 weeks but it will give you recipies and lifestyle choices.
Beware...you will hate cottage cheese after! Look for the cartons with other stuff in it.
Good luck..
I can't really help with the diet, but I would try as many different forms of exercies as you can; weights, running, swimming, cycling, rowing, aerobics, etc in order to find the ones that you enjoy and that fit best into the time you have available.
If you enjoy them then you are more likely to make sure you do them and do them for longer. It also helps if you can do them with someone else for motivation.
If you want to lose weight in the long run, then you should look to make lifestyle changes that are sustainable and enjoyable.
For a few examples carb sources:
Avoid: White bread, biscuits, sweets, white pasta, white rice, chips etc
Eat: Sweet potato, brown bread, brown pasta, quinoa, barley, basmati rice
I lost about 3.5 stone using weightwatches online along with excercise (that I continue, the weightwatchers part was useful for a few months to change habits). May be worth checking out. It's a set of tools and logs that combines your excercise and eating - menu suggestions too if you want them.
What was your weight before you lost the 3.5 stone? If you don't mind me asking :)
10 stone - wow thats a hell of a lot. you should be aiming to lose 1lb per week. which means its going to take a hell of a long time and a lot of determination and willpower, which a lot of people dont have when they are set in their lifestyle.
take in less calories than what you burn.
avoid everything with lots of sugar, fizzy drinks, chocolate, cakes, etc.
its basic common knowledge stuff that everyone knows, well you would hope so.
avoid junk food and fast food, like i say all basic common knowledge.
if you want workouts to follow then you can google them, or buy some of the apps off itunes if you have an ipod touch or iphone.
Well, if you want to lose 10stone I assumed you where very heavy so you wont need to be AS strict to lose weight and will very likely lose a significant amount in a short time if you eat well.
There are lots of similar threads with other members who are currently (or have) losing/lost weight.
Have a search and read through some of these, then from what you've learned there try and come up with a diet & exercise plan yourself. Post it up for some C&C.
You'll find others here are more willing to help when you've had a stab at putting something together yourself as opposed to asking others to do it entirely for you:)
I'd also recommend reading GordyR's Bodybuilding sticky which will gives you useful tips for resistance workouts/building muscle which is AS important for loosing weight as cardio.
If you really want it you'll get there. It takes time so provided your patient you'll reach if not exceed your goals. Give yourself a reasonable deadline to loose the weight by as it makes your goal more measurable and more likely to happen.
Good luck :)
Obviously the first thing is to sort your sedentary lifestyle, and then sort your diet. As Asprilla said go for the usual cardio suspects (though I would avoid running until you've lost some weight).
Best of luck :).
I don't know if the search will bring them up but I've posted in a bunch of atkins/ketosis threads which are basically low/no carb diets and the best way to lose weight, fastest aswell.
1lbs a week is a rubbish target, firstly you shouldn't put a target on as you'll only miss it and feel like crap. Some weeks you'll lose 4-5lbs, others you'll lose nothing or put a couple on, thats life, ignore it.
On a low carb diet(assuming you move from a high carb one) you'll have massive and quick weight loss, its water weight, don't get put off when the weight loss slows. You can literally lose 8-12lbs in the first week or two as for every gram of carb your body stores, it stores 3grams of water, you'll also pee like a crazy person for the first couple weeks. Your body stores a lot of carbs in muscle and liver, and a big guy will have a lot of stored carbs.
No carb is incredibly hard, low carb is easier but very difficult to adjust to as most people are used to eating a lot of carbs as we've had it drummed into us for years fats are bad, carbs are healthy.
Its completely incorrect and opposite infomation, you will die without eating fats, they are completely essential, even the "bad" fats are required to live healthily, just in smaller quantities, carbs serve no essential purpose, you CAN live perfectly fine without them though its very hard to live without them on anything but a weight loss diet.
If you manage to go a week or two on very low carb, you'll actually find your hunger will drop off, carbs increase your hunger, protein and fat curb hunger, keep you full for longer and you don't get the sugar levels spiking as sugar is introduced and removed, thats the main cause for constant hunger we bigger guys tend to have. Once you get into the zone, my appetite just dissappears and weight loss becomes very much easier.
The key is, when you have carbs, have "good" carbs, low GI, things that don't spike your insulin levels and blood sugar levels, basically when that happens your body says, store fats, reduce fat burning, and eat, 3 things you don't want to do when losing weight at all. When you don't spike your blood sugar and don't produce insulin your body tells itself to burn fat, save nothing, keep burning, use everything it can and that it doesn't require outside food sources.
Drink loads of water, keep topped up with vitamin B12(all the b's) as the process your body creates energy to burn fat uses the b vitamins, running out reduces the amount of fat your body can burn.
Egg's are great, scrambled eggs on their own, on a slice of wholewheat bread, with chilli's, peppers, spinach or something stirfried in to make tastier egg meals. Egg's are fantastic for weight loss, good quality fats, filling, healthy, load of B vitamins, no carbs, taste good, relatively cheap, easy to cook, very quick to cook, basically good all around.
Look around some weight lifting/dieting sites, find ones you like with good advice, personally most diet/nutrition sites are filled with "fad of the month" diets, and most weigth lifting sights are filled with guys who have worked out and maintained healthy weights for years and tend to know what works, rather than what a house wife has done for 3 months.
As said before though, don't set targets, if you think you're going to lose 2lbs a week, and you don't, you'll feel crap, if you lose 4lbs and think you're doing great compared to 2lbs a week you thought you'd lose, then the next week you don't lose anything you'll feel like crap.
GO into it knowing some weeks will be good, others will be bad, eat well, do research, work out what food are good, read up on good/bad carbs and find some you like.
I always ate pizza, white bread, and that was about my diet, I never liked brown bread and it took a while of trying lots of different types before I found something healthy that I also liked. I like wheatgerm bread, Hovis, has that moist softness of whitebread but its far healthier. But in general I minimise the bread I eat.
Protein shakes aren't a bad idea, I found them easy, easy to flavour, quick to make/drink and also helps you have a small but nutritious hit of protein. I hate cooking 4-5 times a day in small amounts, so shakes let you do something small, quick, healthy inbetween meals.
And good luck.
Best of luck :).
Rubbish, losing weight is ALL about diet, its 3% exercise, 98% diet. You can run 100miles a day and still eat so badly you put on weight, losing weight is all about diet, gaining weight is all about diet, gaining muscle is largely about diet.
Fitness, strength you exercise to achieve, your weight, is down to what you eat.
I've got screwed up joints, completely awful and exercise is very difficult, losing weight trying to exercise every time for years resulted in an increase in pain, minor weight loss, till pain got so bad I stopped exercising and put on weight.
When I started losing weight by only thinking about what I ate, I lost 6 stone in a matter of 4-5 months maybe.
Good luck :)
I not asking for someone to do it for me, just for some advice which is why I asked for tips rather than a complete diet and exercise plan.
Things like running are out of the question as 15 stone is my ideal weight and I need to lose 10 stone to get there you can appreciate that running is a little difficult and the MultiGym has little or no real instructions on its use.
I don't want to start a specific diet plan as I am looking at a lifestyle change, All the diets I have tried before haven't worked very well, I lose weight to begin with but then put on more than I have lost. My metabolism is completely messed up.
The weight has gradually gotten out of control since I left the Forces, putting on around 9 stone in 5-6 years, added to a serious leg injury which limited my movement for over a year didn't help much.
Thanks for the advice and I will check out the other threads more fully. :)
And good luck.
Thanks, this was the sort of thing I was after. The nutritionist I spoke to said that the way I eat was also a problem, large lunch and dinner and not much else which was causing spikes in my suger levels and forcing my body into 'starvation mode' inbetween meaning I was storing it up as fat instead of burning it properly, which is why she suggested the Low GI foods as the way to go.
My size kinda lets out any kind of hardcore exercise until I have shifted a few stone tbh, so again thanks, Food for Thought so to speak:)
Whoah there nelly. From his first post, I would have said the first thing he needs to change is his sedentary lifestyle. No need to get your knickers in a twist.
Tbh I need to address both Diet and Exercise. My job is very sedentary so I have to fit in any exercise around that, which is why I bought the excercise bike and the MultiGym.
1lb a week is far too little, if he needs to lose 10 stone he must be quite a hefty guy, I guess around the early 20 stone mark, which means the first few months he can take off 5-7lbs a week easily, and it's not due to a massive calories deficit, it will just be his body throwing away the excess crap that's been stored up as fat and water in his cells.
Low carb is the way to go, but don't completely neglect them, at 1 point I did, I ate literally no carbs and I went from being a big guy to extremely skinny, as in 16.7stone - 11.7stone, and when I was 11.7 stone I felt worse than what I did at 16, no energy to even wake up, just felt half way to death constantly all day, it's all about finding your balance.
Just eat 4 small meals a day, people have pointed out what to eat, and drink water, water is your best friend. Also green tea may help you as well (but it's not necessary), tablet form or the actual tea stuff, your choice, I hated the tea so i took the tablets.
