Spec me a PC please? £650
22 Aug 2005
hi guys just about to place an order for a new pc and would like some advice on the best components i could get for £700? i dont need a case but will need a PSU etc
ive also got an OCZ Vertex 2E 60GB on the way but would like 3 additional drives to run in raid 5 for storage. Pc is going to be used for gaming (mostly WoW) and general web browsing etc.
dont think anything in my old pc is worth salvaging (old spec bellow)
Caporegime
17 Jan 2010
weston-super-mare
14 Jan 2010
which chipset is your MB?
would anyone think a Q6600/q9550 + new GPU be a good alternative to a new pc for T180985
26 Jun 2009
Sheffield
7 Jul 2009
Newcastle/Aberdeen
The 4850 you've got is still a pretty competent card, not much point in 'upgrading' from that to a 5770. Depends on your uses, are you happy with the performance you get from it?
Product Name Qty Price Line Total
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail £166.99
(£142.12) £166.99
(£142.12)
Patriot G Series 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGS34G1333ELK) £88.99
(£75.74) £88.99
(£75.74)
Gigabyte GA-870A-UD3 AMD 870 (Socket AM3) DDR3 Motherboard £84.99
(£72.33) £84.99
(£72.33)
Coolermaster CM-690 II Advanced Dominator Case - Black £80.99
(£68.93) £80.99
(£68.93)
OCZ Z-Series 550w SLI Certified Power Supply £62.99
(£53.61) £62.99
(£53.61)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £39.99
(£34.03) £119.97
(£102.09)
Akasa AK-CCX-4001HP Nero S Direct Contact Heatpipe CPU Cooler (Socket AM2 / AM2+ / AM3 / LGA775 / LGA1156 / LGA1366 ) £35.99
(£30.63) £35.99
(£30.63)
Samsung SH-S223L/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £14.99
(£12.76) £14.99
(£12.76)
Sub Total : £558.21
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 17.50% VAT : £99.87
Total : £670.58
OP
22 Aug 2005
changed the budget... what you think of this?
Argon Extreme Intel Core i3 2.93GHz @ 4.20GHz Overclocked Bundle £306.99
(£261.27) £306.99
(£261.27)
Options applied to the above product:
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) £66.99
(£57.01) £66.99
(£57.01)
Sapphire ATI Radeon HD 5850 Vapor-X 2048MB GDDR5 PCI-Express Graphics Card Sapphire ATI Radeon HD 5850 Vapor-X 2048MB GDDR5 PCI-Express Graphics Card £297.99
(£253.61) £297.99
(£253.61)
Antec CP 850W Modular Power Supply Antec CP 850W Modular Power Supply £96.98
(£82.54) £96.98
(£82.54)
Samsung SpinPoint F3 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD203WI) Samsung SpinPoint F3 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD203WI) £95.99
(£81.69) £95.99
(£81.69)
Antec 902 Nine Hundred Two Ultimate Gaming Case - Black Antec 902 Nine Hundred Two Ultimate Gaming Case - Black £84.99
(£72.33) £84.99
(£72.33)
Samsung SH-B083L/RSBP 8x BluRay ROM / 16x DVD±RW Drive - Black (Retail) Samsung SH-B083L/RSBP 8x BluRay ROM / 16x DVD±RW Drive - Black (Retail) £53.99
(£45.95) £53.99
(£45.95)
Caporegime
17 Jan 2010
weston-super-mare
Caporegime
22 Nov 2005
by a few fps... they might have turned turbo boost off or something aswell because the difference in games that cant use more than 3 cores is only 100mhz.
on my 1055t stock settings im only using around 30-40% cpu usage in games as games become better programed for mulitple cores and they will the 1055t would have been the much better purchase.
you can easily overclock a 1055t even on the stockcooler to 3.4ghz
OP
22 Aug 2005
would prefer to go down the Intel route, are the i3 processors a lot slower than the i5? sorry not really in touch with whats considered good anymore
