CM scout accesories..need help!
23 Mar 2010
ok
i was building my PC with a friend...and when i put the graphics card in the motherboard, i had to clip it into place (with that plastic clip at the back of the case for graphics cards).
afterwards i had to remove the graphics card for some cable management.
BUT! that tool less plastic clip snaped...because i had to force the clip in place.
the case came with 1 extra spare clip...but i can see that 2 other clips are about to break... and i need a few more extras
can any tell me where to get them?
Like I've been saying all along... plastic isn't material for such places.
Make sure you get right ones, there are more than one types of those toolless PCI clips (those are keywords) in there.
Scout is from same serie as Sniper so logically it should use same clips but check picture.
Isnt there usually a screwhole where the clip is aswel just incase it breaks? I swear i saw that on one of the CM cases...
You have to push down on the tab inside the case to release the clips. I have had my Scout for almost a year now and have never broken a clip. Coolermaster direct will be your best bet.
That was the only option under the CM Storm range of spares. Probably best to drop them an email. I was only posting the link to compare them with yours.
thanks marvin for the info...althought it looks differnt to my clips =/...o well...as long as it fits
You're right. While there's lot of similarity there are also definitely differences:
http://www.coolermaster.nl/shop/popup_image.php?pID=506
http://www.overclockercafe.com/Reviews/cases/CoolerMaster_Scout/1016.htm
http://www.overclockercafe.com/Reviews/cases/CoolerMaster_Sniper/1018.htm
Nothing nicer than case maker keeping changing parts... although maybe these might be compatible.
I've put forward also inquiry through Coolermaster forum so let's see what they answer.
The more I see this kind weak plastic parts the less I would trust them for attaching anything...
thanks for the help EsaT..il await for your reply when CM forums reply to u =)
