Also feel free to use our OcUK servers. To set them to always get chosen when you start up a game create a new autoexec.cfg file in the left4dead2 game directory and add the following line:
Remove any spaces in the IPs above as otherwise you may get issues (The forum adds them or I would remove them).
Is there anyway to tell I've got that working properly?
Where do I put the autoexec file?
Also, how do I turn on the ~ console? I've got a freeze and sound loop in both TF2 and L4D2 and need to try a possible fix.
when you join it says OCUK in the window that pops up![]()
I'm failing at this. I can't seem to get it to work. The only servers it mentions on the first screen is UKCS.
Not sure - will have to look when I get home.
I do put the file into the cfg folder in the L4D2 folder, yes?
Do you mean I create the lobby?
Yes you will need to Create Game in Lobby
You can also Join the Steam OcUK L4D2 Group,Which Pops up with the Servers when you load the game up
was a good game we had last nightperfect group of people, didn't care what team I ended up on. same again tonight? same people
