Hi again inverseSquare,
Your in a very cool position atm to be able to splurge over £200 smackers on a GPU . . . you may think this is the norm but actually in the RealWorld your in a tiny percentage of lucky few who can do this! . . . the purpose of me posting in this thread with you is to make 100% sure you get the best deal possible . . .
It's obvious from what you have said so far that you really, really "want" a HD 5850 . . and probably have done since the launch when they were £199 but you ended up going with a HD 5770 safe in the knowledge that you could probably sell it to your brother . . . this was a plan you made many months ago and due to the problem with your Brothers system you are getting ready to put that "possibly" flawed plan into action . . . .
I'm not here to tell you what to buy or what you need but from where I'm looking the CrossFired HD 5770's seems much better bang-for-buck than a single HD 5850? . . . . by answering my questions and telling me your objections to the possibility of using a pair of HD 5770's vs a HD 5850 you may help me see some aspect that I previously did not consider!
Yeah, I'm going to be losing the 5770
The future is not carved in stone . . . unless someone is holding a gun to your head of course!
. . . The purpose of this discussion is just to find out if your ideas can stand up to the
Rigours of Logic (lol in OcUK GPU forum!
) . . . and I'm here to learn too! . . .
Does your Brother need a HD 5770 btw? like is he a proper gamer? what was the graphics card he had that died?
TBH I'd be worried about the heat + noise from a couple of crossfired cards anyhow...
I see, I wouldn't want you to be worried about anything!
. . . but hold on a sec "heat + noise"?
Are you "wanting" a HD 5850 so much that your mind in "inventing" reasons that don't actually exist in the RealWorld? . . . or perhaps you are using old and outdated information?
MiNxYyY, JeffyB, hyperst and quite a few other forum regulars using HD 5770 CrossFire setups have not reported any problems with "heat + noise"? . . . if there is a problem do you think they wouldn't share their findings with us? . . . if there is a problem with "heat + noise" I want to know about it and will cease to recommend a CrossFired Juniper config . . . . anyone?
Looks like the 5850 is an ok single card choice then
Well, if it was priced £185-£200 we probably wouldn't be having this conversation and trying to highlight the beauty of a pair of HD 5770s would be a damn sight harder . . . however the HD 5850 is priced at approx £230 which makes it OverPriced for the extra performance it offers . . .
for someone who games at approx 1920x1200 with a rig featuring only a single PCI-E 2.0 X16 slot then yeah I can see the sense but for someone sitting there with an Intel® Core™ i7 system featuring two full PCI-E 2.0 X16/X16 slots and has approx £230 smackers burning a hole in his pocket and who is keen for an upgrade as well as the eventual upgrade to 1920x1200 or higher I do scratch my head at any good reason not to go Crossfire? . . does your rig have two full blown PCI-E X16 slots btw? . . . isn't that one of the reasons the Intel® X58 Express chipset is so ridiculously costly? £££
Kylie Perrin said:
When working in Crossfire mode was impressive to say the least. Although
we are not normally advocates of multi-GPU technology, in this instance it does make sense.
The Radeon HD 5770 configuration was able match or beat a single Radeon HD 5870 in almost every game, and costing around 16% less, that is pretty good value.
While we would not go as far as to say you should forget the Radeon HD 5870 and go for a pair of Radeon HD 5770 graphics cards,
there is no denying that these budget graphics cards are really something when used in Crossfire. For those looking to spend around $300 US on their graphics card budget, we feel that the Radeon HD 5770 Crossfire configuration is the way to go.
Legion Hardware 10/19/2009
Why do we on OcUK forums still recommend a HD 5850 as a better gaming option than HD 5770 Crossfire? . . . does anyone have any negative experiences of HD 5770 Crossfire to report? . . . does anyone who is in the same scenario as inverseSquare (i.e wanting, wanting, wanting a HD 5850) think they would consider a pair of HD 5770's for £25/£30 extra, assuming you had a suitable motherboard processor of course?
Any and all feedback welcome!
