PSU Voltages
Permabanned
6 Jan 2010
Peterborough, UK
OCZ ModXStream Pro 500w - Brought about 3 Months ago from here.
Are these Voltages for the PSU allright, Cause in some cases it is reading Way under the Specified Voltage?
EDIT - Ignore the Dodgey Temp Reading, Its a Dodgey Sensor.
I personally ignore software readings for voltages.
If your not getting any lock-ups or crashed then don't worry.
i know its odd isnt it, been like that since i have had the mobo.
and yeah is a good PSU :)
I bought the modxstream 600w, also about 3 months ago from here, and noticed the same problem. Good to know it isn't actually a problem (i hope :eek:).
