Translation = haha you're screwed
There has also been some complaints that they actually do more bad then good, which range from messing up the airflow and also drawing too much power since they use the same power source
Oh boy. I really hope that Windows 7 doesn't alter the signature... sounds like the only hope I have of this drive being recognised by this PS3 now.
Thanks for your response Senture.
. I'm sorry it is not the news you wanted to hear but I've had my own experience of doing just this and wanted you to know fully.It's pretty difficult finding solder flux over here. I used to repair ECU's with surface mount microprocessors and we always used flux to help the solder.
I tried to find a store in the local area, even called up a few places, but there's nothing. I ended up ordering a small bottle online so I'll have to wait until Friday to repair this now.
my sisters PS3 died via RSOD any idea of fixes
Best result i ever had is when i did an oven profile for a PS3 and stuck in in the reflow oven, thats been going strong for about a year now.MSMALLS74: I'd love to have an nice little reflow oven to pop this into. Actually...could you possibly give a little more information about the PS3 oven profile that you setup.
For instance:
Specifically how long,
What temperature,
Does the oven direct heat in a particular area,
Is there a portion of time that the reflow oven applies cool air,
Did your plastic components on the motherboard become distorted,
etc...
Basically any other relevant info from your profile
One year.... ONE YEAR!!!
I cannot stop thinking about this one msmalls74. It's got me seriously considering using my oven to reflow instead. The more I think about it the more it makes sense, you've got a completely equal amount of heat being applied over the entire board for a consistent duration. Instead of small bursts of heat which could cause the solder to dry, melt, dry, melt and not form correctly.
Please give me some info about your profile, ideally what I asked in the quote and anything more if you have it. It may potentially end up helping a lot of other YLOD PS3 owners.
Sorry to labour the bad news but Windows 7 is just the same as other versions when it comes to encrypted/signed hard drives. Merely accessing it in a foreign operating system that doesn't understand it will have tainted the drive, and whilst the data, etc is likely to all still be on there the PS3 (even if you can get it working) will not accept it.Oh boy. I really hope that Windows 7 doesn't alter the signature... sounds like the only hope I have of this drive being recognised by this PS3 now.
You might end up having to go to Sony after all.![]()
That's fantastic information msmalls74. Thank you in advance for taking a look at the PS3 profile on Monday. Yes, any information you have is very very much appreciated.![]()
I like that tip to cover the parts you don't want cooked, is the "capstain tape" similar to an aluminum tape?
If I upload a picture of the motherboard would you be able to open it in MS Paint (in windows hit Win+R and type mspaint) and draw a circle around the parts you covered?
I've just highlighted all the plastic parts that I can spot on the board (external ports, ribbon cable clips, HDD socket, etc). I'm guessing these are all the parts that you removed! I'm blown away that you removed all of those parts msmalls74, I have no idea how you re-soldered these tiny pins. You must have crazy soldering skills.
