After updating the old Arma 2 to 1.07 I haven't crashed once, I used to crash a lot before that - you should give it a shot, you might be pleasantly suprised mate
any tips on how to become better at the combat aspect of the game?
AA is on LOW and PP is off with 3.6k VD with 60 FPS solid for the most part.there is a update for arma 2 oa
No theirs not.
Stuff......
Seems so......
http://forums.bistudio.com/showthread.php?t=101221
My version is 1.51 ? from fresh install.
Interested in trying this out on my Q6600, stupid question time though - How do I run the benchmark test?.
Also, adding the Quad support shortcut thingy, does the game require to be patched first with the update for it to do anything improvement wise?.
Special delivery for OcUK:
If you have dual/quad/hex cores (Which you all most certainly have) then adding the following to your OA shortcut will make use of all of your cores.
Dual-Core processor:
-nosplash -cpucount=2 -exThreads=1
Quad-Core processor:
-nosplash -cpucount=4 -exThreads=7
Hexacore processor:
-nosplash -cpucount=6 -exThreads=7
for example if you have a quad core like me then you would do the following:
Open your OA shortcut by right clicking it and select properties (not the main .exe, it has to be a shortcut). There should be a directory that is in quotes e.g. "C:\Program Files (x86)\Steam\steamapps\common\arma 2 operation arrowhead\ArmA2OA.exe".
Add the "-nosplash -cpucount=4 -exThreads=7" to the end of the quotes so it looks like this:
"C:\Program Files (x86)\Steam\steamapps\common\arma 2 operation arrowhead\ArmA2OA.exe" -nosplash -cpucount=4 -exThreads=7
Click apply and then OA should now make use of all of your cores.
It worked for me. I have a Q6600 and when I ran the benchmark for OA the average fps went from 25 to 37. There are more tips on how to improve your performance on the official arma 2 forums.
Will that work for the vanilla ARMA 2?
Steam apps ? What about DVD install ? Thanks.
which? he shortcut thingy? yea should do but Arma 2 with 1.07 suppose to have quad core support now
the benchmark is in the single player > missions/Armoury section.
