- 15 Sep 2006
- Liverpool
ABOUT TIME!
Nate
. That shotgun sounds good, but perhaps a tad overpowered ( okay so the clip is halved, this is still obviously the better gun), the normal shotgun packs quite a punch to be honest, if you get crits when you like it you might as well just use engies for attacking...
Had 2 guys get the golden wrench on the server I was playing! Silly me now wants one, gah.
The new shotgun does sound pretty OP, I can't wait to see the whine threads about it![]()
They decided to make is user friendly my getting rid of the old easy to use menu system and replace it with relatively incomprehensible icons set out in an odd layout.
Had 2/3 of a backpack worth of duplicate items to craft but no luck in wrench land, oh well half way to being able to craft a hat now anyway.
The actual update should be good though, demomen will cause much chaos come release.
I'm thinking about playing spy for the first week or so.![]()
