Where?
There was a press release on their site about 3 days ago.
There's a sign up link here, where they will let you know once it has been released
Where?
Goal.com does it for meAny really good Football widgets or apps?
hi
i'm wondering if i have an issue with the switch pro widget and the extended controls widget?
i'd like to use one or the other but i find that when i disable the data connection (apn?) and i then press and hold the power button to check, it still tells me the data connection is enabled even though the H or G logo disappears from the status bar.
As i'm not 100% convinced that either widget is working properly i just use the power button shortcut to enable/disable the data connection when needed. all the other buttons i use on the widgets work fine (wi-fi, gps, vibrate, auto sync and brightness)
in case it makes a difference my phone is an HTC Wildfire running android 2.1 and it's not rooted.
thanks in advance.
On my old C510, they offered the full Windows live messenger on their phone, is there one for android? ive searched the market and the only one that has a rating is msn talk, but people say its laggy.
cheers
i have switch pro as its a small small (i.e size of install). it does work well on my deire with launcher pro
Is there any app that will have live flight info from Gatwick airport?
