Been mad busy with work
Someone sort the file and let the race begin![]()
settled then amd are rubbish at encoding everyone buy intelThe X6's are slightly slower clock for clock than the i7's.
The 3.2GHz 1090T is slightly faster than the 2.93GHz i7 870.
So from that you can say that the X6 needs about a 200MHz advantage to match an i7.
So a 4GHz X6 should be roughly ~3.8GHz i7 for encoding purposes.
Good article here which compares loads of oc'd and non oc'd cpu's encoding:
http://www.techarp.com/showarticle.aspx?artno=669&pgno=2
