bike engined kit cars
13 Jan 2004
Leicestershire
i've seen a couple and i like the nutter element about them i really do but the question is:
how reliable are they? do you constantly have to tinker and tweak them as things wear etc?
i get that they are in no way a 'normal car' so i should expect to tinker and things break etc but i'm just wondering. the bike engines are very strong and reliable - in a bike. But the extra weight of a car has me wondering if it overstrains the engine?
That program on Discovery channnel. Kit car crisis i think. He built one of those bike engined kit cars. A Hyabusa is it. When like ..... off a shovel.
errmm thats my full knowledge used up...
I dont think the engine will have many issues, it will be the gearbox and clutch. Maybe a really low first gear to get it moving should do the trick.
I remember from my time reading kit car magazines that a lot of them tended to suffer from oil surge issues as bike engines aren't designed to take the lateral g forces that a car will generate.
That's true but a baffled deep sump or dry sump setup is often specced for a bike engined kit car anyway so not a huge problem.
As said I would have thought gearbox and clutch may suffer, although this can be mitigated through gearing the car much lower than you would a bike and with regular clutch plate checks/replacement. Regular oil changes would also be top of the list as the increased clutch/gearbox wear would be mitigated by fresh oil on a shorter service interval.
Aside from that there should be very little to go wrong with it. Try sticking a turbo on it too . . . . . :D
They have to have reverse to pass the IVA test now, but there are probably more of them of them on the road without a reverse than with.
Clutches and gearboxes are the main weak point, but it's fairly engine specific.
Theres a couple of nice conversions on youtube
main two that come to mind are
EscortRR - mk2 escort/cbr900
Hayabusa Golf - mk2 golf van/turbo hayabusa
Thanks for all the replies. I think this issue could be sorted ala my friends goldwing sidecar as that has a reverse - its runs off the starter motor so technically you can only use it very infrequesntly but it works. :)
I have a Megabusa,finished building it last year.
Its covered 1400 miles so far (wish it was more :( work gets in the way)
It depends on which engine you choose as regards sumps. Some you can get away with using a baffle plate. I personally wouldn't run a Busa without a dry sump lots of £££ but then the original engine cost was even more £££'s.
I am always tinkering with my car but I think that's the nature of the beast especially as I built it myself they are never quite finished (in your head at least)
Since getting it on the road I have replaced the standard exhaust can which had a cat in it.
I have recently fitted a flatshifter :D which then meant having to fabricate new bracketry for the paddle shifter.
As has been mentioned if you are building now you do need a reverse for IVA but there are off the shelf solutions available now anyway.
I personally do not have a reverse gear and as long as you think ahead when parking its a not an issue.
I did put up some pictures of the build a while ago have a search under my username.
Email in trust if you have any questions
Steve
just to reignite this...
westfield and caterham seem to be the biggest players but what about:
Locust seven
Fisher fury
Tiger Avon (every tiger avon i've looked at i've really liked the look of but never heard of them!)
I did look into putting a GSXR1000 turbo engine into a smart car..... as you do.... in terms of a daily driver its not really an option. The main problem is the car is heavy compared to a bike so when your in traffic you have to give it a fair amount of revs to pull away. obvoiusly the clutch wont last very long, plus even if your driving along at a legal speed it sounds like your doing 100 and can attract the police.
Had the option of having a V8 given to me for a small fee. it works and runs etc. From a chrysler though and i know very little about them. all i know is the car ia from late 70s early 80s i guess.:confused:
