Overclock Celeron e3300
I wacked one in to a gigbyte p31, and with out any hassle i got it to 3.2, with some extra volts and tweaks i reakon 4 ghz could be possible. Not tired any higher as it was for my dad
Foxconn boards tend to be pretty basic in terms of overclocking features. It's probably FSB limited and doesn't allow you enough control over RAM speeds/timings etc.
Anyone know the maximum safe voltage on stock cooling? at the moment i have it on 1.288v at 3.339GHz, everytime i rise it i get BSOD.
It's stable according to Orthos.
should be alrite with anything up to 1.4v, temperature depedant, you just need to increase it and keep trying. But keep an eye on the temps for sure.
Hawker
Hawker
What would you say is the max temps? i've got it on 1.4v, 3.4GHz and idle is around 28c and load is 69/70c
the limiting factor is the RAM, its cheap ddr2 667MHz and maxes on about 800MHz
Think you answered your own question. :) If you really want to max out the chip you're going to have to change your RAM and upgrade the cooler a bit.
How convenient, was just about to post a thread about these chips.
Currently stressing an e3300 under an H50 at 3.75ghz, 300x12.5. Load temps after 5 mins at 46. Here's the kicker, it's at stock volts. :)
Now either I've got a holy grail chip, or I've misinterpreted the BIOS options on my GF9300 and it's doing something like auto volts but CoreTemp reads a vid of 1.2875v.
Any thoughts, other than "he must be smoking crack"?
Well i've managed 3.5GHz 280x12.5, my load temps after about 5 mins are 70c, however this is with the stock cpu cooler.
but volts is 1.4
I want whatever you're on. :p
Nah seriously though what voltage does CPUZ show when idle/under load? You might just have got lucky with that chip.
Sadly I'm now on a comedown, Orthos croaked so I had to put some more volts in. I'm at +0.8 IIRC in the BIOS now and loading it up at 4ghz. 2 hours down and so far so good, temps however are now up at a more believable 65.
Still really pleased I've finally managed to get a chip that hits 4ghz, previous efforts all fell short at around 3.8. Typical it was a £40 chip that managed it in the end!
What RAM are you using?
OCZ PC2-6400 @ stock for the moment, 4-4-4-15. It's going to hold me back for sure, plus it's only 2gb so I'll be on the hunt for some 1066 stuff.
surely you guys can drop your multipliers further than that, even at 300FSB 1:1 is 600mhz on the RAM, unless ive totally ballsed that up?
Im running an old 1.8Ghz single core [email protected] - 400FSB using DDR2 667 OCd to 800mhz
Hawker
