Finding it very hard to play at the moment, I keep on getting ridiculous lag spikes where the whole game will freeze and the ui disappear. Sometimes it won't even log in. It was fine last night, but there's probably a lot more people playing now. Has anyone else had similar problems?
Can't say I have, but this is a beta. Get over to the tech support and post the issue, see if they can get it fixed.
Calneon - Yes, you can exit battle once you're dead and join another battle using a different tank. Once the original battle's finished you'll get the credits as normal. gold is awarded every 24 hours after registration, it seems. If you registered at 5pm, you'll get it every 5pm, though its only awarded after a battle, so you'll need ti fight to get it. Just recieved mine, not going to spend it on anything right now though, saving for premium methinks.
Tips and tricks I've picked up so far: Hang back at the start! Follow the group, don't lead it. Being near the front means you're going to be the first target, and first to die. Keep back and shoot targets as they appear. Try to hide in vegetation cover, you can see out but its harder for enemies to see in. Meaning its safer to sit there and take pot shots at enemies as they appear. Once they realise you're there, start moving. Acceleration is slow, and zig-zagging is the best way to avoid enemy fire. Yes, if you're running away it means exposing the rear armour, but in the first few tanks there's only 2mm difference in armour thickness.
