- 7 Mar 2005
- LU7
Pray, do tell me more. I think I might have a common problem then?My market is busted on 2.1
You've given me an idea. I might downgrade and see if the last 4.x version works.Hmmm... do I upgrade to 5.0.8 tonight. I like Market working...![]()
I'm on 4.2.15.1 and have never had a single problem since doing it.
I want something fresher though, might go straight to the 6.x RC1. Been backing up everything all day, so nothing to lose really.
I'm going back to 4.2.15.1 now. 5.0.8 is nice but if Market doesn't work at all I can't install/uninstall/update apps at all.I'm on 4.2.15.1 and have never had a single problem since doing it.
I am now.All ok now then?
90% of the time when I go into the Market, if I search for an app or look at my downloads it'll load the expected screen, then bounce me back to the main market screen after about 1 sec, the same thing often happens when I try to download apps from there too.Pray, do tell me more. I think I might have a common problem then?
Anyone had any issues with the other keyboard that Cyanogem comes with? Once I select it as preferred input method I get the 'stopped responding' error message.
