 - 25 Sep 2008
 - Orsett, Essex
^ So cool
 This is why:
 Looks like the motherboard was drawing too much down one or both of the 12V wires and the powersupply didn't have enough features to prevent that sort of surge or whatever, the jury is out on it right now.
I watched the video from the seti thread. The cards look so good with those blocks on. Would be good to see some pics of the system when you have it finished.
Oh and this is cool!
As some of you know weebeastie hasn't been well latelyThis is why:
To test a mobo that was giving me trouble from another rig, I thought I'd use weebeasties PSU to see if the other machines PSU was faulty.
When I tried to unplug the 24pin cable from weebeasties mobo it was a mite difficult to do so and required a bit of judicious wriggling and carefull prising to get it off, and then when it did come off I noticed this:
The PSU has been RMA'ed the motherboard is still working as far as I can tell, there is no scorching other than the pins, the board itself is ok or so it looks, but I'll know more when I get it back together. But its crunching a bigadv as a test and seems ok so far.
Now I'm not sure when this happened, whether it was during normal folding/crunching duties or when I was testing tri-sli or when I was benchmarking furmark or what, no idea, I do know that the machine started to shut down on its own a few times but put that down to just normal clocking instability.
Anway, I'm moving the GTX480 to my regular rig and bringing the GTX470 from that to put into weebeastie, that should lower the power draw hopefully enough to keep the plugs from melting.
For reference incase you didn't know the PSU was a Xigmatek which is a Thermaltake rebadge 1500W PSU and its been sent back to be tested but I've got a replacement already
I'll put some pics of weebeastie in its prime before
Surely however this was more down to a particular problem with the PSU or motherboard than the draw of the cards. Most of the power for graphics cards these days is taken via the PCI-E power connectors as I understand the PCI-E slot draw is capped at around 75W.
Biffa, isn't 1500w overkill? I'd of personally put my money in a 1200w Gold unit.
