GTX 460s - Who is getting some for folding?
23 Nov 2002
Near Bristol
Looking at the price and GFLOPs rating of the new GTX460 they look like they could be great value folding units. I know GFLOP isn't the b all and end all of PPD rates, but it at least looks promising.
Anyone planning on getting some? Would be interesting to see how the PPD stacks up against the 465 and 470.
Mark
Due to the redesign the 460 is actually more efficient clock for clock than the 465/470/480, so in theory they should be grand number crunchers.
It might be a bit of a nightmare as it seems a lot of companies are using different board designs. If there is a standard Nvidia board then there will probably be blocks for it.
But definitely this looks to be the next GTX260 for folding on. You'll have to overclock the nuts off it to catch a GTX470 and then power use starts to match the card you are trying to catch, but even highly overclocked its some 70W or so less :)
So yeah probably a great card as they removed stuff from the card not really used for folding/boinc.
Yeah, very true. Although I'm sure some of the 800MHz factory OC versions will give the 470 a run for its money. Tempted to get a pair of EVGA standards and flash them to Superclocked vBios.
Hopefully HeX can give us some info if his card turns up today.
But it does have higher stock clocks (perhaps because of the optimised architecture/lower power draw=less heat etc) so will probably o/c higher than the 470s :)
460's are clocking to 800Mhz.. thats what I am saying, a highly overclocked 460 might reach a stock clocked 470's PPD but by the time it does it will be eating the same power as a 470.
But then you can clock a 470 to 480 with a bit of a voltage bump.... But...
By the time you clock a 470 to 480 stock PPD its eating the same power as a 480 at stock, and then you can overclock the 480 out of the park :D
ad infinitum... till you run out of PCie slots or burn out your PSU and mobo :(
That is true, but price is the other factor. 800MHz factory clocked 460s are £200 where as stock 470s are £260+. Even if the 460s are slightly slower, they may still workout as the best ppd/£ cards.
Guess we need hard data, hopefully there will be some in the coming weeks.
hard to tell with all the goings on at borkley but I reckon 13 or 14k per day on seti
I think the stock 460 price is good but even allowing for overclocking I would rather have the extra cuda cores...
Overclocked, between 14 and 15K in my standalone rig.
Here are some stats from the evga forum that I used for settings:
GTX 480 Clocks & PPD
SimC33 --- GTX480FTW HC ----- 1945Mhz / 2230Mhz ------- 19,552.00 ------ (257.15 Beta)
Sledgehammer70 --- GTX480 HC ----- 1802Mhz / 2002Mhz ------- 18,786.22 ---- (257.15 Beta)
xxx --- GTX480 HC ----- 1789Mhz / 2124Mhz ------- 18,173.8 ---- (257.15 Beta)
xxx --- GTX480 HC ----- 1700Mhz / 2110Mhz ------- 17,029.20---- (257.15 Beta)
SimC33 --- GTX480 HC ----- 1700Mhz / 2000Mhz ------- 17029.16 ---- (257.15 Beta)
xxx --- GTX480 HC ----- 1644Mhz / 2048Mhz ------- 16,470 ---- (257.15 Beta)
SirMasterboy --- GTX480 SC ----- 1650Mhz / 2100Mhz ------- 16,470 ---- (257.15 Beta)
Danger30Q --- GTX480 ---- 1550Mhz / 1960Mhz ------- 15,501.2 ---- (257.15 Beta)
Avengingangel --- GTX480 --- 1504Mhz / 1932Mhz ------- 15,058.29---- (257.15 Beta)
GTX 470 Clocks & PPD
ajr23 --- GTX470 ----- 1670Mhz / 1800Mhz ------- 15,997.1 ---- (257.15 Beta)
heydabop --- GTX470 ----- 1605Mhz / 1875Mhz ------- 15,501.18 ---- (257.15 Beta)
techmasterjoe --- GTX470 --- 1580Mhz / 1850Mhz ------ 15,291 ---- (257.15 Beta)
xxxx --- GTX470 ----- 1580Mhz / 1701Mhz ------ 15,058 ---- (257.15 Beta)
jpeck2009 ---- GTX470 ---- 1555Mhz/1700Mhz ------ 14,664 ---- (257.21)
theGryphon ---- GTX470 ---- 1480Mhz / 1850Mhz ---- 14,100 ---- (257.15 Beta)
xxx ---- GTX470 ---- 1480Mhz / 1800Mhz ---- 14,050 ---- (257.15 Beta)
Dave851 --- GTX470 ----- 1497Mhz / 1755Mhz------ 14,000
taniquetil --- GTX470 ----- 1440Mhz / 1675Mhz ------ 14,000
700_up --- GTX470 SC ----- 1250Mhz / 1705Mhz ----- 12,277 ---- (257.15 Beta)
Barbarossa--- GTX470 ---- 1215Mhz / 1675 MHz ----- 12,256.7 ---- (197.75)
GTX 465 Clocks & PPD
Thor88 ---- GTX465 ----- 1520Mhz/1603Mhz ----- 13,169 ---- (257.21)
Barbarossa ---- GTX465-----1215Mhz/1603Mhz ----10,350 ---- (257.15 Beta)
