nice psone dude i havent seen them in a decade
There should be a gap in between the graphics card and the motherboard that you can route it up, just remove the card, lay it in place and slot the card back in.![]()
@ringo747
can u rout the 20+4 pin and the 4+4 CPU cables around the back of the case? seems like there are holes cut for it? or are they to short?
yeah thats wat i found hard about my case aswell, getting the 4+4pin CPU cable through the top holes is such a pain, they put these holes not thinking about that the rail the side slides onto is in the way of the hole.
looks great for a first build but!
love this one so clean.
