Glad i waited...
16 Feb 2010
Just looked here and for some reason 5850 gone down, got mine for £199 XFX one!
Also treated myself to windows 7
£310 delievered! bargin.
Shane
About time prices were back to what they were at launch, they should get even lower now considering how long the cards have been available and that there is some actual competition from nvidia.
Can't see then dropping much tbh, the 470 isthe competition to the 5850 and that's not dropped :/ roll on the refresh :)
the 470 dropped £25
it's £235 now, £199.99 for me who in their right mind would buy a 5870 or 5850 over it unless the noise was an issue
the 470 dropped £25
Are you saying the gtx 470 is a better buy than the 5870?
The price difference between them is about £50 at the moment.
Im not trying to be smart here. Im in the market for a card, and had previously considered the Zotac 470, but was told it would run loud and hot, so ATI was the only option.
Have been considering one of these:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-003-HS
http://www.overclockers.co.uk/showproduct.php?prodid=GX-002-HS&groupid=701&catid=56&subcat=1502
do you use headphones for gaming?
if your answer is yes or you would be fine with using headphones and use the price difference between the 470 and 5870 to buy some then get a 470
if your answer is no then I'd probably stick with the 5870
don't worry about heat, as long as it doesn't kill the card it's fine, plus the GPU doesn't get that high in games any way, 85C tops or 75C with a well ventilated case (I keep the side off mine because the noise doesn't bother me and I get 820MHz 1050mv 77C tops with my 470)
maybe he's using a ridiculously low res screen where the ridiculous amounts of AA you can use on nvidia cards helps
