- 15 Feb 2010
When i first installed windows 7, including updates it booted in 30 seconds about 20 of which was bios. But now that i have installed SQL on it and used about 40% of the drive in total it now takes 40 seconds to boot!
I used crystal disk; on the "supported features" line it has there SMART, 48Bit LBA, NCQ and TRIM in black; APM and AMM are greyed out. I have version 1.1 of the firmware. Do i need to enable TRIM within windows?
I have not enabled AHCI in bios yet on my ASUS P5Q pro turbo; is it on automatically? If i do this will it affect the data on my drives / would i have to reformat or anything? I tired to enable ACHI in the main option but i got a blue screen when i booted into windows; so i enabled the ACHI controller only in the advanced tab is this right? Do i need to do anything else?
Thanks
Thanks
