Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
Can't see anything on the official forums. They still need to fix the bronze star award thingy and the spec kits AND add some new maps finally.
Does anyone else lunge forwards in their seat when attempting a knife kill?
I just did it, and hit my head off my speaker. Hungover BC2 is bad.
ROFL!
On another note, i think i might start this up again if the majority of problems have been fixed.
Well ever since the new patch i have had two problems.
1. It said toggle crouch was enabled, except that doesnt work. did they lie to me ?
2. game crashes with sound loop about 3 mins in, every game.
Solution ?
FIX:
Remove X in "Allow Punkbuster" in Options menu.
You can only play on non-PB servers though.
OR
Just buy an Asus Sonar D2X add-on soundcard and
disable your on-board sound driver so you can play
with Punkbuster and sounds without the hang-up, it
worked for me (using Vista x64).
So now i have to spend £100 on a soundcard just to play BC2 ? I think not.
Solution ?
You have to tick toggle crouch in the settings menu where you adjust your res etc.
My game crashes all the time now as well and I have a D2X...
i realy need to come try this game again, ive only played 30 mins since latest patch, i got the hump with bigger hitboxes for moving players as i like to move around a lot :/
il come back as sniper :D
i would happily pay £20 for 4 new maps, love the game, but feel like i 'know' the maps to well and its a sprint to get to the hot spots and kill zones when a ,map or objective is reached (i only play rush)
Does anybody have the link to the latest patch? Fancy giving this another bash over the summer holiday.
Does anyone have an issue in game where it will have 3 long bursts of lag then all will be fine for 10-15mins. it used to completly crash / brown screen till they did the new updates but I still get the glitchy lag a lot. :(
