- 17 Aug 2003
- Woburn Sand Dunes
install at shutdown should be a standard option. you lot need to get off your horses.
The view is so good up here. Peasant.
yeah it happened to me I just changed the setting a bit....
and it makes you install all updates before SPs >_> althrough you can get the stand alone
at least its not like linux were you have to type in the root password![]()
Upgrade to Windows 7
and next time, maybe take a minute to go through the windows setup where you can change the option before you even go into windows for the first time.
Yes and yes... So you concur it's a poor and illogical default behaviour? Thanks!Also, I believe the default setting in Vista gives a dialogue box saying the system will restart in X minutes. Most likely you won't see it when playing games in fullscreen.
