- 2 Mar 2004
- SE England
Old Lexus LS400 + boost + N2O + Intercooler = 700BHP+.
Briefly, maybe, but it'd run the 1/4.
Early MKIV Supra 6 speed, probably pick up a shabby example for around 5k.
2JZ-GTE engine is solid, good for silly power (would need to work on internals to have it last any massive length of time though)
6 Speed GETRAG box good for silly power too.
£5k left for big single turbo kit and some new cams, obviously you would have to fit it yourself.
Job done.
R32 GTS-T, GTR if you can get it in budget, with a massive ridiculously laggy single turbo setup? First thing that springs to mind. Beyond that I'd agree with the above 2JZ Supras.
Old C4 Corvette : £3200
HP Performance complete single turbo kit : £3800
Forged 383 stroker kit : £550
Larger-bore performance exhaust system : £350
Performance fuel system : £250
Performance ignition system : £250
Uprated radiator : £230
Uprated oil cooler : £60
High performance trans rebuild kit : £89
TCI Torque convertor : £180
67mm turbo upgrade kit : £900
Total cost : £9859.
Hell, you could even give it a good service as a bonus![]()
Resulting power at this point : Circa. 1000-1300BHP & 800-1200ft.lb without nitrous.
Obviously that's a bit over what you were looking for but hey, why have 700 when you can have over 1000!
You could reign it in a bit though, save the £900 on the 67mm and retain the stock 60mm turbos and that would run 800BHP and 700ft.lb - which would be more than enough and a bit more controllable, less stress on the car as a whole too.
You could build a real budget 700BHP C4 for a lot less but that's just a quick example with off the shelf parts - for example you could buy just the car, the forged 383 kit, a few intake and exhaust bits, and a 200BHP shot of nitrous and you'd be up to and over 700BHP without too much fuss, for a few thousand quid- so you could spend money on the rear end, suspension, tires and brakes to make it a really streetable car
A standard Viper Green 1.4 Scirocco 10K deposit, rest on finance.
After tuning to provide 20 degrees of total timing and a safe air/fuelmixture of 11.75:1 (with the supplied injectors), we were rewarded withan even 500 hp at 4,800 rpm and an incredible 611 lb-ft of torque at 3,800 rpm. As expected, the addition of 8.3 psi of boost pressure simply amplified the naturally aspirated power curve. The horsepower still peaked at 4,800 rpm, and the engine speed for the torque peak was actually reduced from 4,000 rpm to 3,800 rpm. Even more impressive is that the HP Performance system has room to grow should you decide to build a dedicated TPI turbo motor. Seven hundred pound-feet at the tires, anyone?
turbotoaster, the kit comes with uprated injectors (but I specified £250 quid anyway to further uprated the pump/fuel pressure regulator/filter system).
With regards to controlling the fuel, you use the car's original ECU - The original chip can be removed and completely reprogrammed to any specification desired, so you only need an EEPROM reader/eraser/writer (or know a decent tuning shop) to get it bought up to spec with regards to keeping the fuelling right![]()
I believe the kit I specced is supplied with an appropriate base PROM for you to drop in depending on your setup, which may get you bang on the money anyway.
The stock transmission and diff won't handle that kind of output all day long but they will put up with it for a while, before you pretzel a driveshaft, provided the traction is the weak link. Just a case of balancing the upgrades so you get the best combination
Here's a later LT4 engined C4 with a single turbo kit:
906BHP and 896ft.lb! AT THE WHEELS!![]()
turbotoaster did you used to have a renault 5 turbo?
i did wonder about the fueling, but since it looks like just sticking a big pump and fpr on there than 250 should cover that
the reason i asked about the ecu was because i think the old corvette was N/A hence i dont know if you can rig up a cheap GM 3 bar map sensor to read the boost or they are just adding in fuel at set rpm vs throttle position
Im suprised the diff wont take it because a lot of rx7 lads pinch the corvette rear end when they start running 9s qtrs or faster
i did indeed yes, do we know each other?
.get an orange, burnt out, two-jay-zee (no ****!!) which is in fact a 3.0 non turbo supra and then put 15 grand of over night parts from japan under the hood
easy
the only advantage jap/euro cars have over the americans is weight but then when your going in a straight line the ability to massively outpower your closest rival in power to weight makes up for the cornering performance to an extent.
Nothing a good bit of carbon fibre and lighter alloys can't sort though
In the festival park old days, going back a few years now. I was the idiotic one who got banned for racing.
I dunno, a Corvette is quite light in some respects - in order of weight:
E46 M3 CSL : 1385kg
Corvette C4 : 1469kg
Lexus/Toyota Soarer : 1596kg
Porsche 928S : 1629kg
Supra TT : 1642kg
I think a TT RX7 is about 1300kg? So the Corvette is almost 200kg fatter than thatNothing a good bit of carbon fibre and lighter alloys can't sort though
Even something like a mid 80s Camaro V8 usually clocks in around 1500kg, so not too bloaty - but definitely getting up there.
Your job is to build a car that will do 700bhp for a total of £10,000
You missed the point a bit there..., id get a mini shell and whack a hayabusa turbo engine in it
Really? You think they're ugly? Never had a bad word said about any of mine, had to beat people off with a stick for the most part
Strange lad
You have to remeber that these things were designed in the early 80s, for one thing........
Anyway, we're here for 700BHP talk, continue![/QUOTE]
I think you should be banned for posting such porn.
Might as well just sell the DC2 and get one of those proper cars. That C4 in black looks sexual!
