Any easy way to enable aa on an ati card here?
theres a borderlands start up manager, wich lets you change everything from AA to FOV, going trhough res, and mouse smoothing its awesome
check it out, i searched in google "borderlands config launcher"
Just a repost for all those who have recently bought the game in the Steam sales, here's a link to show all the ini file adjustments which make the game much better to play
http://gbxforums.gearboxsoftware.com/showthread.php?t=79043
Here's a link to the config editor tool which makes all the ini file changes for you
http://gbxforums.gearboxsoftware.com/showthread.php?t=85874
Are you sure the diamond isn't hidden away directly on a transition point on your map (eg you are in the wrong zone for that tracked quest)?
Cannot play Borderlands anymore
After a few minutes the screen goes blank, sound is still there and if i cant get to the task manager then i have to do a hard reboot
Why is this happening all of a sudden![]()
