- 15 Sep 2006
- Liverpool
PhoenixUK, low tier attacks at the start are part of the game. You say no games ever get to higher tech because everyone just attacks with tier 1 units, well that's just not true. Every game goes up to tier 2 sometime after the first 7-8 minutes. If you aren't surviving that long then you're not playing the game right. Starcraft isn't just about big battles. You're not allowed a free ride to high tech, you have to work hard to survive to be able to get to high tier.
Also, if you constantly make svc's, you can still afford enough tier 1 units to survive. If your opponent has no intention of teching, you will have a better economy than him because he will cut scv's to make units. This might mean he will have more units than you - but he will be attacking you at your base. Build bunkers, use the high ground advantage, block your ramp with buildings or more bunkers. If he has a lot more units than you and you defend it successfully, you'll be in a great position to counter attack. Or turtle and tech more if you really want to.
You shouldn't be losing to the first rush. If you are, your build isn't optimal. It also sounds like you're against building more than 1 production building. I'm sorry, but you'll never win if you decide to build just 1 barracks. It's just the way the game works.
