So again its about 100 quid.
Is this premium worth it?
Does it need 10 pages?
To some the extra is.
To others its not.
Its that simple.
That's some progress there, I see you've moved from " You need to spend all money you can to get the best otherwise you won't even be able to run notepad on the cheaper AMD system " to " To some, the extra premium for performance is worth it BUT for some it's not ".
That's a huge improvement there hahaha.
Either way, I think that many of us forgot about one very important factor and got benchmark obsessed too much.
Everyone is too busy looking at every 1% decrease or increase on XYZ benchmark that we forget about the most important factor when buying new PC which is - "Will it run the stuff I want at the speed I need it to and will I be happy with the performance ? ".
Many probably sometimes won't notice the difference even it's as much as 20 or 30% simply because they're happy with that 20-30% slower machine and that's all they will ever ask for and there will be no problem at all but then they see a benchmark which shows that XYZ CPU is better than theirs by 5% in ABCD benchmark and that's how everything starts.
I get amazed with the amount of people spending weeks in order to get the best gear they can just because they "multitask " - having winamp, few tabs in firefox, download manager and photoshop open at same time ( which obviously needs 980X to run since it's such an intensive multitasking ). So then they spend massive amount of money just to get that setup which does 20% faster in benchmark regardless of the fact that for the past 5yrs they've been running a pentium 4 PC which is 5x slower than the which would be 20% slower from the one they want to splash money on.
The only advice I could give to anyone buying new gear is to ask yourself those 2 important questions:
- Will it do what I want it to at the speed I want ?
- Do I need it now ( Buy what you need now, not what you might need in 3yrs ).
