- 31 May 2006
- West London
Been busy in my lunch hours working up the coats of paint.
Good clean, rinse and dry (paper towels, then air dry for 20min's)
Mask up foam (as required see below)
Gray primer mist coat, 15mins wait
second coat, 15mins wait
Flip and repeat (mist, wait, coat, wait)
store in warm ventilated room for 24 hour
sand (1200 grit) (see above)
Rover Atlantic blue base colour mist coat, 10 mins wait
second coat, 10 mins wait
third coat, 10 mins wait
Flip and repeat (mist, wait, coat, wait, coat, wait)
sand (1200 grit)
wash, rince, dry, 20 mins wait
Ford Azure blue top mist coat, wait 10 mins
The two small panels are at this stage now, will be applying the lacquer on thoses tomorrow.
Motherboard tray is being removed if I have the time tonight (as that requires a system rebuild in my second case
Each panel (doing the two small panels together) needs three 'fair weather' days to paint!
This week so far has been very productive, but the guys and girls in the office are starting to ask lots of questions
Shaking an spray can ever 10 minutes does tend to get noticed
sand (1200 grit)
