Soo tempted to Jailbreak for LockInfo and SBSettings and Wi-Fi Sync.....
Just do it. If that's all you're using it for then it's fine you won't get bogged down with all the other useless buggy crap they got on there.
I couldn't even find it. I found a iBlueNova and i put it on my ipod touch and turned on my bluetooth, opened the app and then enabled it, which disabled my bluetooth. was buggy etc.
I put it on my iPad which obviously isn't iOS4 and it pretty much did same thing.. um
IBlueNova doesnt use bluetooth I think and uses BTStack?
You need to SSH into the Application's folder, and replace icon.png with a newer one. As you mentioned...are there any high res icons at present?How do you individually change icon's for app's? And anywhere I can get the full iphone resolution messages icon?
You need to SSH into the Application's folder, and replace icon.png with a newer one..
im getting rid of it now.
just restoring my phone.
cant personally see any benefit from having it jailbreaked.
some might but i don't personally and im sure it is good for some people.
You shouldn't even have to add it the info.plist. I've never had to do that with any of the apps I make. OS4 on iPhone 4 looks for the @2x.png first, if it can't be found uses the original.
Apart from those I don't think ill use anything else but very happy
I get this feeling too. My iPhone 4 just feels a little bit more sticky. I unjail broke it and only installed the features I like and didn't install winterboard - still doesn't feel as good but for the features i've got i'll live with it.I'm thinking about un-jailbreaking mine and going back to standard. Only got Five icon dock, SBSettings and a few SBSettings themes installed, Cydia etc but the phone just doesnt feel as "snappy" as it did before. Might just be my imagination, not sure.
Winterboard appears to slow down pretty much any iPhone I've tried with a JB so it could be that.
Apart from SBSettings and the ability to quickly and easily change custom SMS tones, can't really see much point ( for me ) in sticking with a JB. I'm not really one for swapping around with loads of themes etc anyway. As others have said, each to his own though. Might JB it again at some point if I feel the need.![]()
Loving the jb phone I have now
How do I activate 5 dock icons? Installed but can't find where to turn in on?
Thanks
