Solar tech as it is now, is completely unfeasable on any grand scale, because we can't produce the things on any grande scale, they are VERY expensive to make and use expensive materials.
On a bit of a tangent...that particular argument only applies to solar panels, not all solar tech. While obviously useless for road surfaces, other forms of solar tech can be of some use in some circumstances. It's feasible to make a useful power station from what are essentially mirrors. Relatively cheap to make in large volumes from common materials and the numbers work out if you have them in a desert. It's about generating electricity from heat rather than the light used by photovoltaic panels. The mirrors gather heat, the heat is used to generate electricty by a variety of means. Concentrated solar power.
EDIT: This isn't purely theoretical - there's a 30MW CSP power station in Seville and the completed power station there should generate 300MW. It's also by far the best looking power station in the world. Less pretty but in some ways more practical CSP power stations exist in the USA and China. They're talking about getting more than a GW from the USA ones, and that's a fair sized power station. This stuff works, scales almost linearly with space (lots of space in deserts) and has practical generating costs now.
