I've got a i7 920 D0 @ 4.2Ghz 1.4v 200x21 on an Asus P6T
With the H50 and the system under 100% load on all core with HT on I am hitting 100°C and the system is throttling back
 After boot up it idles at 55°C
This is outside a case with fans in push/pull on the H50 radiator.
What I am not sure of is if the kit is faulty or if I am just asking too much of it.
Why am I concerned its faulty? Well the block/pump doesn't even get hot and the radiator is cool.
Fans all at 100% bios settings all switched off for fan profiles, even have the pump running on a 12v molex adapter from the PSU rather than the mobo headers, although I have tried it on every mobo header as well.
When I turn it on I can hear the pump start first.
I've stripped it off and fitted it again a couple of times, the notches are all in the right place in the rings and its tightened down as far as it will go. Could there be a problem with the mounting ring coming loose?
I'll try and get some pics when I get home but I heard such good things about this and I bought it to replace my swiftech H20-120 kit ready for my q6600 to i7 upgrade but at this rate I think I'll have to dig through my spare parts box and throw a custom rig together.
 After boot up it idles at 55°CThis is outside a case with fans in push/pull on the H50 radiator.
