I am in the process of finalising the components for my very first build so as you can imagine, i don't know much about motherboards.
I have decided to use an AMD X4 955 CPU that will be overclocked to about 3.8-4.0GHz and need a decent motherboard to go with it.
The maximum i have to spend on the motherboard is £100. For this i need, in order from most important, to be able to overclock an X4 955 CPU,have integrated graphics, have USB3 and Xfire or SLI options however the last two aren't majorly important so you could skip them.
I also have no brand preference as i've never build a PC before.
So can anyone suggest or recommend a motherboard of their own that i can use?
