I get a constant 6meg/sec 24h a day from newsgroups.
Moving soon though to a non cabled area, going to be sad times indeed![]()
ive gone from 50meg steam downloads to 60k a second max. Fun times. Fun... (beacuse ive moved aswell)
If you are on ADSL that is your problem mate.
6.9, how does that work out :S?I get 50mb 24hrs a day.
I get a solid 6.9mb's through Giganews all the time, and have an avaerage ping of 6-10 in all games![]()
I have the uuh, L package, up to 10Mb
The utter limit of 50Mb is 6.25 so I declare lies
10Mb VM BB is fine in Bristol atm.
Oh do you? Well i can assure you when i download through giganews, my connection speed is 6.89kbs, give or take a few kbs
Why do you only use 5 connections?
I use 20.
This is my astraweb connection.
20 connections
which is 6.36Mbps, which is still higher than the numbers your saying i can achieve.[/quote]
Erm, no. 6336.9KB/sec equates to 50.69Mbps, aka 6.34MB/sec. Well within the realms of the figures I posted above. ;) You said you were getting 6.9 MB/sec, a much higher figure. :p
20 connections
snip
Well I don't see how that is possible.
50M/bits / 8 = 6.25MB/sec - overhead = ~6.23MB/sec
10M/bits / 8 = 1.25MB/sec - overhead = ~1.23Mb/sec (Thats what I get from astraweb with 5 connections - IE the utter MAX my connection can have)
What does your TaskManager say?
You might be one lucky person who gets more than the 50Mb!
Whatever you might say 6.25MB/sec is the utter transfer limit of a 50Mbit connection, unless my networking knowledge is completely out of date, but living with a Computer Science dude Im pretty sure im correct![]()
