would it be worth it for me to invest in a q9550 or above? I'm reluctant to upgrade to an i5/7 atm due to new socket coming out soon.
I think the question i'm really asking is am i bottlenecked by my CPU in games? and if so should i upgrade.
Compared to what everyone else is getting it is a bit low. What have you got the memory at?? 2000?i5 750 @ 3.4ghz Seems a bit low?
so is that palit one okay to get now? hows the warranty on it? still very loud, vrms over heating? how long is it? is it smaller than 10"?
No problem with the palit after the updateany idea on length? is the fan noise present with the new bios?
Just ordered the Palit GeForce GTX 460 Sonic 1024MB GDDR5 PCI-Express Graphics Card.
Price seemed good. Not pre-OC'd but not bothered. Could always try it myself. Bit-tech reviews seemed to suggest buying a 1GB over 768MB if you could, otherwise would've bought the 768MB version.
