This reminds me, if you have a shroud, do you also need a gasket? Also, what function does a gasket serve![]()
the gasket reduces vibrations
At 600rpm they are inaudiable, yet the water loop will be removing much more heat as water is a better conductor and the radiator has amuch larger surface area than any of those heatsinks.
Watercooling being quieter than air cooling used to apply to the old days when air coolers used high speed 80mm and 92mm fans but a single 120mm / 140mm low rpm fan on a pipe cooler will always be quieter than 3 low rpm fans on a radiator plus the pump noise for the sake of a extra 200mghz overclock.
And anybody that thinks a computer running with temps in the high 30s is better than a computer with temps in the 50s is suffering from OCD as all you have is a lower temp reading in task bar.
Thanks everyone for the replies. It's kind of confirmation I needed.
I know the science behind the conduction and convection. There's more to it than just the surface area
Water is fine. But the question is will I test ethylene glycol and R-113 in the water cooling loop as the working fluids!![]()
why would you want t unless running sub-zero? - they're worse coolants.
Glycol and R-113 give decent heat transfer rates.
On another note I'm seriously tempted to design and manufacture my own rad...
there huge!
From my investigations in the lab, and from investigations from other instituitions (I'd be happy to link to these, however they're not free on the science direct website), glycol and R-113 do provide pretty decent vapour side temperature differences via coolant conduction. This was for vapour side mind, however I'm confident that it'll be same for coolant side.
Do it! What kind of thing did you have in mind? Would be interested in seeing a deep, widely spaced fin radiator with lots of louvres on the fins.
I've heard the idea of air being saturated before - but if that were the case surelyy the air exiting the radiator would be at the samp temp as the water exiting the rad, and it isn't iirc.
The pa series radiators and similar deep widefinned ones don't perform above narrow-finned ones because there's a comparable or less surface area.
The reason why i thought deeper radiators didn't do so well was that after the leading edge of the fins (where air first meets the fins at the front) the film of air over the fins as the air goes through becomes heated and insulates the fins. Louvres introduce new leading edges - tourbulance the the pips and breaks up the insulating air and introduces fresh, cool air to the fins. I know that's how it works for passive airflow - could be that low speed fans are enough to introduce turbulance and break up the insulating layer anyhow.
Not trying to preach to the converted btw - hoe it doesn't come across that way (I know you've done quite a bit of work on heatsinks)
