Good Windowed Case
13 Sep 2009
Maidstone, Kent
I'm looking for a good quality windowed case. It should have a large window, good airflow, good quality, black interior and not be a HAF-X! Also, the side window must be on the left, which unfortunatly rules out most of the SilverStone cases. I am looking to spend between £60 - £130.
Any suggestions?
I would recommend the Antec 902, not to everyone's taste but it's really very good. If you're after a larger case, the Antec 1200 is exactly the same, just bigger. :)
way under budget but i will vouch for awesome airflow. if you can handle the style of it. if you do used both 120/140mm in the top you cant have the dvd drive in the top of the case (no problem for me as i stuck my fan controller there instead)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-NX&tool=3
Thats exactly the style I am looking for, but looking for a bit more quality. I think I may mod my In Win Ironclad as I really like the quality on it.
I really like the HAF-X, but is just outside my price range :( I love CMs design with the HAF-X! Anything you can think of with a similar design? I would rather go with a full tower, but will go with mid tower if I have no other option.
I have a Lancool K62 and I am very happy with it. Its is B-E-A-Utifil :D
Also, the blue LED fans look great but I have also added some blue cathodes for extra effect :D
http://www.overclockers.co.uk/showproduct.php?prodid=CA-026-CS&groupid=701&catid=7&subcat=1489
I'd wait for the corsair 600t and get a windowed side panel for it that they will inevitably release later, there's already huge demands for a windowed side panel or windowed version and it's not even out yet.If you cant wait the lancool is pretty much a lian li in disguise but with top exhaust fans which the lian li's don't have.
My current case the fortress ft01 is still worth a look even though the top fan filter issue but you can run top fan as exhaust to bypass that issue.Not to be sniffed at at the right price really is an amazing looking thing in the flesh.
I think I have decided on modding the HAF 932, put a big ol' window on there! If it all goes wrong, I can always buy a new side panel!
