MX-2 is the best bang for buck these days. It's only minimally behind MX-3 in performance yet can be picked up for a mere £2.59 a tube now. AS5 is prehistoric now and should be left to die. Why wait 200 hours for full performance when you can have it instantly?
I have just swapped from MX3 to Gelid Extreme and I must say I prefer it. Glid covers the cpu much better than MX3 and my temps dropped a few degrees at load.
Yes it does, and if you read the roundup that came from (on skinnee labs website) then you will see that the indigo extreme is a near-perfect thermal compound.
BUT, it doesn't work like a normal compound. You dont squeeze it from a tube like all the others. It's a solid metal that melts under heat. It comes on a single-application card that you place on the cpu. You then 'cook' this card, by not using a fan or pump on your heatsink, in order to melt the metal and generate the seal.
It's about $20 for two applications, only works with LGA 1366 CPUs, and I've not seen it for sale over here.
The shin etsu compound is the winner of the traditional thermal compounds in that roundup. By far. Though ski.nee still likes MX2 because it's easy to work with.
