Is best for overclocking and also is the quietest? Should I just go with the cheapest? http://www.overclockers.co.uk/showproduct.php?prodid=GX-148-XF&groupid=701&catid=56&subcat=411
Well that one has a reference cooler, so the overclocking possibilities arent that great, but then again its the cheapest one going by what you said.
Its a matter of whether you are willing to pay more money to get better overclockability.
XFX also have a lifetime warranty which may be something to consider, but that means you cant overclock if you like that idea.
Reference design means best overclocking abilities because you can tweak the voltage. Plus there are quite a few coolers you can purchase later on
XFX doesn't sport lifetime warranty in the UK - only in the US. It does however have Premium Priority warranty with OcUK, which could be really useful if your card fails at any time.
I agree that HIS Turbo with MW2 seems like a good buy anyway. You get a game worth £20 plus non-reference cooling and decent overclocking capabilities.
So the HIS one you are talking about is this one? http://www.overclockers.co.uk/showproduct.php?prodid=GX-003-HS&groupid=701&catid=56&subcat=411
So its best to go for a reference design so that I can tweak the voltage to get the most out of an overclock? How do you tell if its a reference design, does this just mean not modified with a different cooler?
Yes, that is HIS one I was talking about. Afaik it doesn't allow you to tweak voltage but they overclock fairly well at stock and have really good coolers.
Reference designs are for those who either cope with noise (like me), want to watercool (like me) or are looking for an aftermarket cooler (like me also) for their graphics. The good thing about them is that they allow you to flash BIOS from other cards such as Asus or MSI to get rid of standard overclocking limits (775/1125) or just use Afterburner/AMD GPU Clock to override them, they're compatible with all waterblocks and aftermarket coolers and allow you to control voltage. They are hard to get these days but I believe XFX is one of the reference rev.1 cards. Sent OcUK a webnote if you're interested.
Interesting, it sounds to get quiet and a good overclock then I will need a reference card, but these are noisey in comparison to a non reference, but these are cooler and are limited.
Hows about getting the £209 xfx reference card and an aftermarket 30 odd quid cooler. Must be the best of both worlds then?
Yes, but you're looking at spending almost £240 on it. It's worth it though, especially if you don't mind voiding warranty. Wouldn't it be better to find a used Asus reference on warranty (they all must be, haven't been out for a year yet) and getting an aftermarket cooler? You wouldn't have to flash BIOS then in order to bypass overclocking limits. There's a lot of options tbh but as I stated earlier, you can overclock with that HIS, although you won't achieve as good results as some do with reference models.
Sent OcUK a webnote if it's a reference PCB card - http://www.overclockers.co.uk/showproduct.php?prodid=GX-148-XF&groupid=701&catid=56&subcat=411
This will save you some money now, you'll get a direct warranty with OcUK for 2 years and you can voltage tweak anyway. If you want one more year of warranty then go for Asus one, although as far as I'm concerned, changing the cooler may void warranty (it may not be true though, I'm not even sure if it's sealed anyhow). There are also 2 games to sell with that XFX card.
Reference cards can bump voltages, make sure you can change the cooler without voiding warranty too.
Lol, spelling mistake - "Send OcUK a webnote and ask if it's a reference PCB card"![]()
