Would this PC handle Windows 7?
12 Dec 2005
Just wondering if the following PC would handle Windows 7 without too much slow down.
Pentium 4 2.4Ghz
512MB Ram
40GB HDD
Quite an old PC!
It'll run but it won't be mega quick. If you set it to Windows Basic (if Win7 doesn't do this automatically) it'll at least run a little easier. If you can upgrade the RAM to 1GB+ (2GB is ideal) it'd be a big advantage. The kids' desktop is a Celeron 3.2GHz single core with 1GB DDR RAM and that runs Windows 7 just fine for browsing/email/YouTube etc.
it depends on too many factors, you will ahve to jsut try it...
I have vista on a p4d 3ghz dual core, with 1gb ram and a 80gb drive it is considerably faster than a core2 2.4 / 3gb ram dell I reinstalled for someone..
if your CPU is a celeron with 128/256 cache and a 400mhz bus forget it, however if its more like a 2mb/800mhz and the hard drive is fast its worth a shot...
The CPU is fine. It would be better to have 1GB and a new HD though than just going to 2GB imo as the HD will be really slow.
Pentium 4 2.4Ghz
512MB Ram
40GB HDD
Quite an old PC!
What are the full specs of the PC? DDR RAM?
Have sent you an e-mail which might be of some help :-)
J
Yes it will run but more Ram is needed for a reasonable performance I advise putting a copy of Windows 7 on and trying it before buying.
