rFactor F1
Also is there a way to have more than one mod installed at a time?
Just install more mods as you have the F1 mod and switch between them by changing the race series in game, or select all cars and vehicles. Works for the extra stuff I have gotten.
Have also been trying it out offline to practice a bit and might jump on the server at some point, but really gotta learn the track unless there is a way to get a map on the hud :p
Ok will try out some other mods later maybe. Saw a gokarting one which looked awesome fun.
I have the same problem, the only track I know 90% would be the nuuremburg (sp?) f1 track
Picked up some of the easier ones like montreal and nurburgring after a few laps, but I think in spa, it was the last and first corner that still always get me, so maybe another sessions going around might allow me to try increasing my speed :D Must say, i do find it a enjoyable trying to learn the tracks, adds in a little more excitement!
Yes, I beleive it is possible to have more than one mod installed. Log1k is going to sort that when he's back from holiday. He mentioned something about the BTCC mod.
As far as im aware there is no way of getting the HUD the display the track. What does Google say?
I think I've found a guide on how to set tracks to load on the server. So Suzuka later hopefully. I'll take a look when I get in tonight. It'll be around 8ish I reckon so if anyone's in the server and it starts behaving oddly its me. I'll post on here once I have it sorted.
Any other requests for tracks?
There is a nice mini map plugin I have been using.
http://www.rfactorcentral.com/detail.cfm?ID=Map Plugin
+1, makes learning new maps a bajillion times easier. There are also some F1 style TV HUDs that make hot lapping more enjoyable.
As for new tracks, I know Monaco has a lot of close walls (it really isn't that hard), but it makes for some amazing qualifying sessions, and we seem to do a lot of hot laps.
Will probably pop on tonight, there is no race on simraceway tonight.
It's the map plugin posted above and the TVStyles mod. There are a few guys ripping each other off, but I think this is the best version. It's a bit of a faff getting both plugins working together though.
Here it is in action (without map plugin):
I use the TV style but I have a big problem :p I use Eyefinity so its about 30cm away from my eyeline -> You can edit positions but that never seemed to work for me O.o
Hey Guys,
I've taken a look at the Tracklist, taken the rubbish ones out and got Suzuka loaded.
Current Tracklist is:
Spa
Suzuka - Can be downloaded here: http://www.rfactorcentral.com/detail.cfm?ID=F1 2009 WCP
Montreal/Canada
Silverstone (Old Circuit)
European GP
Monaco will done either later on tonight or tomorrow evening. Hopefully there wont be any problems with the changes. If anyone notices any please post it up.
Evening
I thought I would check this out but it looks as though your server isn't up atm. I'm interested in having a go if I'm welcome, although a total n00b. When's a good time? I can usually play Thursday, Saturday and Monday evenings..
Everyones welcome mate.
I've just had a quick look. I can see and connect to the server.
Have you got any server filters?
Hop on anytime. If now one is playing do some practise/hotlaps???
Thanks mate
In all honesty I have no idea if I have any server filters on - I can't see where I would configure that. I'm just starting up, clicking 'NT JOIN' which brings up a list of servers. Where can I configure server filters?
*edit* nm just found it, just being blind. Off for a try now.
*edit* Downloading Suzuka.
You're not being blind, rfactors server browser is terrible. It will only show around 400 servers, after it finds 400 any other servers will be ignored, so you just have to keep refreshing until you find it.
If you open in rfactor/userdata/*profile name*/multiplayer.ini (about 20 odd lines down) and edit the line that says "Concurrent Server Updates" to the value of 999, you should have a better chance of finding it.
Gonna jump on in a sec.
