Nvidia beta driver v259.32 !
Caporegime
8 Sep 2006
On Ocuk
64BIT
http://forums.laptopvideo2go.com/topic/27205-v25932-windows-7vista-64bit-nvidia-desktop/
32BIT
http://forums.laptopvideo2go.com/topic/27204-v25932-windows-7vista-32bit-nvidia-desktop/
Feedback
Instaled these give the highest custom TF2 timedemo benches by 10 - 15 fps
Very nice set for me, got +10-15 FPS in Mafia II demo (w/o Physx), compared to the previous 259 releases
yes they're better than 259.12quadro and allot better than 259.31 - smoother and lowest fps is also good;
Wow, these drivers are great!
I gained about 4 FPS in Crysis (2560x1600 with extreme quality mod), and the framerate is much smoother with no dips..
Also tested Metro 2033 and my average framerate was 4 FPS higher than with the 258.96.
Download driver , download modified inf , copy inf into unpacked directory (overwrite) and install!. Some of the best drivers have been modified inf ones :cool:
Yes me , they work fine no problems to report... As for frame rates generally they are the same on the games i've tried
Excellent news. I have just installed these myself as well (straight over the top of the previous ones, I assume this ok (it is for ATI drivers).
Will try another run of Mafia 2 (once I download it again - I want to see if the claim of 10fps+ is accurate or not).
Most say that's a bad idea , some say this is ok too... Myself i always clean up old drivers and install. ;)
Ok I have ran Mafia 2 and lost 0.6fps which is within a margin of error (so basically the same as before).
I would love to know where this has come from:
Overall its basically the same as before.
Do me a favour please
Go into Nvidia control panel and then on system information and components
Do they all say 5932 ( apart from 534.04 last two )
Just checking something , btw about people getting a huge increase sometimes you get that with certain systems.
[DEV_0E22] NVIDIA GeForce GTX 460
[DEV_0E24] NVIDIA GeForce GTX 460
:confused:
Yeh, still not in the modded file I downloaded, however, they still installed, so what do I know!
Seem to be good drivers so far, had an increase of 900+ points in 3Dmark06.
Yep, apart from what you mentioned, and the physx.
