Watercooling fitting, what is it?
10 Jun 2009
Darlington
Hiya.
For all you guys out there who watercool im wondering if you can help me? Ive bought a 800D and want to fit a fillport on top of the case. This bit is easy. I have a dual bay xspc res and I want to connect the top fill port of the res to the fill port im going to put in the top of the case. What is the name of the fitting I need for the top of the xspc res? Ive seen someone do it on the this forum but I cant find the post now, any help
Cheers.
Looking at the photo of the one that's on OcUK, it looks like it's a non-standard thread, but you're basically looking for a barb with the matching thread to that.
Edit: At a guess from it's size compared to the G1/4 threads on it, it might be a G1/2 thread, but don't quote me on that!
Search for this XSPC M20x1.5 to G1/4” Reservoir Fill Cap Adapter.
Details:
• M20x1.5 to G1/4" reducer fitting
• Specifically designed for XSPC Bay Reservoir filler caps
• Use this fitting to attach a T Line to the top of your case for filling.
Compatibility:
• All XSPC Bay Reservoirs
• XSPC DC 750
• XSPC DC 400
• XSPC Laing DDC Reservoir
its not a standard thread i not sure you can do it i have one my self (well just put it up for sale) what i do is unscrew from the case pull it out a bit and unscrew the cap fill it up that way
Details:
Compatibility:
• XSPC DC 750
• XSPC DC 400
Spot on mate. Thanks for that. Just what im after. I dont want to be having to take of the front panel etc. Thanks again.:)
