Which card do you reckon?
16 Jul 2010
Hello guys, I need a bit of help.
I recently purchased a p45 chipset motherboard (Gigabyte GA-EP45-UD3LR) to go with my GTX280 but for some weird reason the 280 doesnt work on it,
I've tried everything to get it to work i.e re-seating it, changing psu etc, the 280 works on an older motherboard though.
So i've had enough with all that messing about. :confused:
At the minute I'm running an old 7950gt and after looking around for a decent motherboard I'm kinda thinking about just buying a new (lower end)
graphics card instead and then using the 280gtx later this year when i upgrade to an i5 or better.
Trouble is which graphics card to get? Looking to spend around £100
Wanna use this card for gaming @1680x1050 and also want to link it to my tv for HD movies so was thinking of getting a lower end ATI Card.
Which is better for what i need?
5850
http://www.overclockers.co.uk/showproduct.php?prodid=GX-155-XF&groupid=701&catid=56&subcat=708
or older 4890
http://www.overclockers.co.uk/showproduct.php?prodid=GX-124-XF&groupid=701&catid=56&subcat=938
Any help would be much appreciated
cheers
The 4890 is a lot faster than the 5750, and faster than a 5770 - the only drawback being that it doesn't support DX11 (well they run hot and use more power too). If you are looking for DX11 support then i would recommend saving an extra £50 for a GTX460 768mb, you will get a substantial jump in performance for the extra cash.
If you're not too worried about DX11 then the 4890 is a good buy though.
Cheers Nocky,
Not bad for just a few quid more, but will that 4890 gimme me better framerates over the 5770?
I only really play steam games but looking to purchase startcraft 2 and a couple other games.
cheers
@ p0rks0da
@ franco_22
cheers for the info too, was typing as you guys posted :)
is my 280 better then the new 460? for the future, cos if it is i can offload the 280 and have more £££
Not sure what to get :P
Cheers Nocky,
cheers
If that's the case I'd definitely go for the 4890 mate. Its great in source games and starcraft 2 should run admirably :)
The GTX 280 and GTX 460 are very equal in performance, maybe an extra 5% from the 460.
4890 is better then the 5770 but no DX11, so that's for you to decide if you want it or not.
Selling the GTX 280 and buying a GTX 460 1GB then overclock it would be what I would do if it was my card.
Cheers Guys I appreciate your time.
Looking at the 1 yr warranty on the 4890 is kinda putting me off but i do accept that its old tech now so i can't ask for much more.
Looking to upgrade in a few months so i don't really wanna spend much more then £120. I think i'll keep the 280 and go for either the 4890 or the 5770.
Wish there were more decent motherboards around, as i wouldn't of come unstuck.
Again thanks for the help ;)
