Show off something
That's a classic.
I'll have to join the motors boys because mine has to be:
Your name is Craig Kennedy, live in East Kilbride and you were born in 1983 I presume? That's enough for our (incredibly creepy and scary) OcUK detectives you know. :p
He hangs about the McDonalds and Archers Sleepcentre car parks in that motor.
I can practically move my HDTV to any position now, really helps with posture and visibility when sitting back from the desk. The happiest I've been with a purchase for quite some time.
[IG]http://i33.tinypic.com/10ne1wy.jpg[/IMG]
What model is the stand? Will it work for Eyefinity setups? (3 monitors side by side with a bit of angle on the outer screens.) I assume it just clamps to the edge of the desk?
Where did you get the arm mate.. Been after one to fit a 24" with good movement..
Cheers
