Phenom II X4 955 95w version. I think there is a X6 1055T 95w version too, but it depends if you want speed or more cores.
Depends on the application, for some things the 1055t will be faster if the task utilises more cores, for some the 955 will do better because of the higher stock speed.
If you clocked them to the same speed the 1055t would be the one to have IMO.
Thanks! so the X6 1055T it is then. Just looked OcUK has no stock left & no ETA. Can't find nowhere else that sells this chip
Anyone finds one available PM the details. That would be greatEdit. Found one! WOOOOOO
Edit again. I found the 125w version bahh. Again let me know!
I have a 95w 1055t and i run it 3.5ghz and then turbo to 4ghz.. Its a superb chip even and barley hits 40.C at max load with only 1.2v vcore..
They seem to have stopped selling them for some reason..? No idea why. Tempted to ebay mine as i got it quite cheap....
The 1055t 95w can only be sold as a bundle unfortunately.
Msg/email me if you want to get hold of just the CPU and Motherboard separately![]()
Frozennova is correct, it is because of the terms AMD have laid down with this CPU no retailer can sell it seperatly as it is for system intergration only.
Have you tested the processors? are they on average better than 1090T for overclocking?
