Gaming PC for £800
25 Aug 2010
My 5 year old computer broke last week and i've decided to buy a gaming computer. I want a pre-built as I don't want to make it myself in case I mess up.
So can anyone suggest a good one for £800?
Thanks.
tbh mate building a pc now is nearly IDIOT PROOF, everything fits in one way, there is a fantastic guide on how to build a pc, i think you have to go to general hardware and it should be the second post, and cable maangement is very easy all you need is cable ties and some adhesive tape and yo can do just as a good job as a pro. £800 will get you a VERY good gaming pc in terms of price/performance if you build it your own trust me mate, unless if yo want to spend around 1k for a per built one, thats with a SSD for OS and couple of games and a very good GPU, and the operating system itself for e.g
Only comes with a 4850 for £800, would be around a grand to get a graphics card that did the system justice.
I would go with:
Intel
http://www.overclockers.co.uk/showproduct.php?prodid=FS-252-OK&groupid=43&catid=1444&subcat=
With a 470
AMD
http://www.overclockers.co.uk/showproduct.php?prodid=FS-033-OP&groupid=43&catid=1444&subcat=1713
Ask for a change to 480 during the order process
do u need the OS as well ?
if not, then u could go for the Titan Exodus with GTX470 for about £820
or with a GTX460 for abit cheaper
with an OS, then u could get the Titan Exodus with Windows 7 and GTX460, for just over ur budget.
what res is the monitor ?
