Steelseries Sx advice?
12 Jul 2010
hey
i got my self a steelseries sx, its a aluminion mat, the problem is that it isn't flat,
its bent very slightly, so its like a seasaw so if i lean on the left, the right side up rise a small amount. is this normal & exspected or should i ask for a replacement?
also any other fixes will be helpful.
http://i37.tinypic.com/dv51f.jpg
theres a little space where the mat meant to be gripping to the table, & i lean on that side the other side goes up by that much.
well the mat costs a bomb & i plan to use it over 2 years so i do want it to be perfect, i do have the right to be picky.
Course you should ask for a replacement. Why do people even make these threads?
You buy it, if it's faulty or not performing up to par then get a replacement. You don't have to feel sorry for SteelSeries, pretty sure they have more money then you.
well yeah thats what i was going to do but i didn't know if theyre all like that or not.
yeah i'll go get a replacement
Call me crazy here, but...
is your table flat?
Have you actually tried seeing if something known to be flat (like a T-Square or a Spirit Level) sits flat on the desk?
